Glo pulgs replacment on e46
riaanm03
hallo
just need advise on glo plugs,
i am replacing the swirl flaps on my car, while the manifault is removed if i should replace the glo plugs
the car has 125 000 km on the clock
nothing seems to be wrong with them
thank you
zaleonardz
Have a quick scan to let you know if the plugs are out, could be that one or two have failed up till now, and then just replace those.
At 125 they should be good still....
zaleonardz
diagnostics is the only real way without effort I would guess.
Have you priced them yet, how much are they ?
zaleonardz
Yep, the afraid too part my be very valid.
We actually have a forum discount on vasaline with BMW SA..... :spit:
netercol
yeah diagnostics is the best way to know if the glowplugs are good or not, other methods not so reliable.. (measuring their resistance ect.)
you can find good quality NGK or BOSCH glowplugs on ebay for not too bad prices, better than stealer prices.
on a side note, i have 3 dead on my 330d (according to diagnostics), but i have not bothered to replace them, as they very rarely actually do anything in our climate. (they should more or less, depending on model, only switch on if ambient is below 5 deg/celcius)
however, i was told once by a bmw tech that the ecu uses the glowplugs to monitor combustion .. never could confirm it.
