Finally strutbrace Fitted
gconry18
Selling Already?
http://capetown.gumtree.co.za/c-Car...sories-BMW-e46-Strut-Brace-W0QQAdIdZ307387769
frikkieh
Burgy@ProjectShift said:
Guys the struts do fit the pre FL E46's. We've fitted one to a 1999 E46 323i
+1 , Just ensure the studs are long enough.
Modding for me was just not worth while.
frikkieh must have the reinforcement plates in his shock towers that are taking up some of the tread...
i just noticed something:
did the e46 ever get wipers like this? or did you retrofit them...
R700 is alot when you can buy the rubbers and slide them on fro much less... hopefully aftermarket ones will come on sale before i need new wipers...
andrewbuch
You can get aftermarket ones :)
But I have tried a few different makes(Of the old type ones) including bosch and they all have sucked.. Will never buy anything else other than the ones from BMW
calypso
andrewbuch said:
I paid about R700 if I can remember correctly... Worth it.. they work brilliant..
I paid R450 last week. Maybe there has been a change. But the look identical to Bosch Icons. Im sure its them just rebranded.
andrewbuch
Could be that my dealer is in a posh area so they add a "fee" onto it to make it seem better quality as most shops around here do..
But was that for both (whole wiper & not just the rubber?)
frikkieh
Apologies - For not posting the pics sooner. Here are the measurements that can help some prospecting customers decide :thumbs:
you studs seem to have the same amount of tread left as mine when bolted to the tower... so it looks like other pre F/L might also have this problem... i can go check tomorrow...
Iceman007
Ja that was me just wanted to see the respons. I Actually got an response and some chancers. So Projectshift you can make some money. As You can see people are searching for it.
The only time ill sell it is when I sell my car. It works graet and thats why there is no phone number on the AD
frikkieh
Found very interesting reading :
http://www.rogueengineering.com/rogue/StrutB/RE_RB.html
Extract:
"a strut tower brace made entirely of aluminum or magnesium would be most affected by the elevated temperatures of an engine compartment. This may be fine on a strut plate, but if the centerbar were to expand, this would negate any benefit of the bar since it would change the suspension settings in a negative manner (usually increasing positive camber). Since the heat of an engine compartment can exceed 200ºF, this would cause an aluminum or magnesium center bar to start expanding. Simply switching the center bar to steel would cut the variation by nearly 50%. Of course, switching to carbon fiber would make the expansion virtually immeasurable. "
Iceman007
BMW is selling the upgraded wipers now and they work much much better
Caution Caution they are pricy at R595 a set
