AngusCPB
Good morning everyone, just looking for some different opinions on this.
I've got a 2013 520d F10 with 185xxx km on the clock.
I have been experiencing vibrations throughout the cabin (can narrow down to the rear of the car) when accelerating under load between 1400rpm - 2000rpm. I can feel as well as hear the vibration/humming, more so at 1600rpm. The vibration gets worse when the car is in a higher gear and more torque is applied.
I have recently replaced the following:
-Engine Mounts
-Transmission mounts
-Rear differential busing
I inspected the rear driveshaft guibo and found it to have some decent cracking, but I'm not 100% sure this is where the vibration is coming from.
The car has Stage 1 software, so more torque.
Rear tyres are currently on the bare minimum mark and need to be replaced - however I know for a fact that it is not related to tires at it is dependent on torque and rpm.
What are your opinions? Do you think replacing the guibo will fix this issue?
I have attached some photos of the guibo.
Thanks!
-Engine Mounts
Thanks!
