Engine swap - N20 into E36 ??
zabbo
So, I have been offered an E36 328i Individual with a blown motor at a decent price.
Having always considered boosting as an option on my previous car, I now seem to have the perfect opportunity.
Option 1:
Repair blown motor (guy says parts are there ... lol) and add a turbo! Simple ... but so boring :=):
Option 2:
I happen to have a 320i (N20) engine from an F30 with a manual gearbox which will be available soon. With a few simple mods this could push out in excess of 250kW :=):
So now the only question is ..... how easy will it be to transfer the N20 motor into the E36 (with or without the gearbox)? I have all or most of the electronics available from the F30 as well.
Please only respond with a high-level answer as I am by no means going to understand any technical jargon which may be offered in support of your response :=):
... Also, not sure what the final setup/use will be (but it will be street legal) i.e. drag, race or top-end.
option 1 will give you more head room or power later on but the N20 is lighter and should be more efficient as well as have smoother power delivery
tough choice... if you will be happy with the N20 power then overall probably the best but real performance cars are now pushing 300kw+ so the N20 might not be worth the effort
Gizmo
Banned
Rebuild the 328i motor for boost, use a 330i crank for 3.0lt displacement and avoid all the headaches involved in making a N20 work properly in the e36, let alone making it all fit correctly. Built 3.0lt turbo will have double the power and is a tried/tested recipe, no need to re-invent the wheel here.
Major
Yeah, the novelty of having an N20 in there would wear off as soon as you paid the bills. :)
Also, a 328i turbo, boring?
:hammerhead:
Nikhil
And because cast iron :cartel:
bac
Will be a cool swap, was considering swapping a n54 into z3 m myself, biggest issue is the injectors/fuel pump issues electric so not supported on local management, also if swapping over f30 electrics/dme/cas etc, if anything is missing on unplugged and car goes into limp mode, than screwed. Gonna be a mission to get it running 101%. Rather boost the m52.
zabbo
All valid points - can get my hands on a S54 motor too but I will need to source the electronics!!
DieselFan
Bruce craigs has a e46 m3 they're stripping if you're going to go that route
Major
And an E60 M5 last I was there. :mmm:
DieselFan
They have a m6 v10 not a m5 afaik. And they're trying to sell the whole car for like R350 000. And not parting it out. Which is why it's been there for like over 2 years.
Major
Oh OK, my bad, saw the engine and no front end.
zabbo
Thanks.
I will make a turn there.
Maljan
Or you could do this:
modp-1304-06-o%2B1992-bmw-325i-e36%2Bchevrolet-LS1-V8-engine
Kinda sacrilegious but should be good for way more than 250kW. :RedNo:
zabbo
Dhp507 said:
2jz.........all u need
That is correct ... cheap, easy, power -- what more would I want??
But that is sacrilege!!
Only a BMW powerplant for me thank you. (Thanks for the suggestions anyways).
Dhp507
Some would consider boost sacrilege also.......an just a thought the 2jz was homolagated in Germany ..
Maljan
Just for the record, the picture shows a Chevy LS1 in an E36 325i, with an Eaton M112 supercharger from a Ford Lightning on top. It all ended in tears when a radiator hose burst on the drag strip. The car skidded on its own coolant and hit the wall. Kinda sad, the previous run was 11.96 seconds while taking it relatively easy. Perhaps it was Karma, who is a bitch (as the saying goes).
http://www.superstreetonline.com/features/modp-1304-1992-bmw-325i-e36/
