Eccentric shaft sensor failure
Beemie320i
Would a bad 'oil leak' repair job result in the failure of the Eccentric shaft sensor?
It wouldn't quite be of any good to replace the Eccentric shaft sensor if one still has an engine oil leak, would it?
Please kindly advise.
Thanking you in anticipation:bangdesk::cry:
Beemie320i
Just a follow up to the Eccentric shaft sensor failure;would the engine symbol come on and stay on if the eccentric shaft sensor fails?
lavishkid
Hi I also have the same problem oil is leaking from my eccentric shaft sensor causing the sensor to give error codes and reduced power.
Did you find the answers you looking for ?
