Speedy said:Sorry to hear this man, it really kills the joy of owning such a car.
How can they attribute a current issue to something which happened so many KM ago when no problem was noted at that time. seems a bit touch and go to me.
I would definitely try another dealership.
Hotclutch said:So much for some tuners claiming that applying software is undetectable and won't void motorplan. I think the question that needs to be answered now for the OP is at what point the software was applied. Would be a bit unfair if he bought the car in good faith and did all the necessary checks wrt to mplan and now have to deal with this.
444YYY said:A manual can over rev, say if you change from 5th to 2nd - by mistake. (at high revs)
Even though you have a rev limiter, a missshift from 5th to second will force the engine speed to conform the wheel speed for that gear, as they are connected mechanically.
444YYY said:Guys, read my post below.... Stock and remapped cars can overrev !!!
I was making an exaggerated case of 5th to 2nd, but say you are in a hurry, you downshift from 4th to 2nd at low revs, and miscalculate the anticipated revs, and you mistakenly overrev it to 9000 rpm. This is the more likely scenario. You many not see any damage immediately, but the ECU will log the over rev.cOlDFuSiOn said:444YYY said:Guys, read my post below.... Stock and remapped cars can overrev !!!
Cool my bad must have missed this.. Makes sense, I thought that you would blow the clutch or gearbox before you damaged the engine if you tried this?
