Dirtydeedsman
Sigh... E92 is beautiful
:blowheart:
:blowheart:
Kameelzn14 said:Very nice wright up on this beauty she is a real gem, i especially like the Alpine white colour and the style 313 wheel combo.
How about some pre maintainence advise for a fellow 325i N52 owner. I have mine for just a little over 2 months now and read earlier in this post that you changed the water pump as a prevention. What millage would you recommend the water pump be changed at. Im currently sitting on 81000km's
Also do you maybe have the part number for the Bosch coil packs that you changed, reason being i would like to buy 1 new coil pack and keep it as an emergency spare should i ever need it.
SubLoaded said:Kameelzn14 said:Very nice wright up on this beauty she is a real gem, i especially like the Alpine white colour and the style 313 wheel combo.
Hi Bud,
Seemed to have missed this. I'm nearing 160k KMs and I'm still on the original waterpump - with no signs of anything wrong with it (however I've read that it can just pack up suddenly without warnings). I've seen some that have packed up on low KM cars and I know of some cars with > 250k KMs and still on the original part so I don't really know what to tell you on this one.
I don't know the exact part number but I got mine from Goldwagen (just give your VIN to them and they should sort you out.
These cars a solid and rarely give trouble. You will probably encounter ticking sounds upon cold starts. I am experiencing this. It's the hydraulic lifters and it does not have any negative consequences on the motor or ride and it's just a nuisance more than anything else.
Your oil filter housing, oil cooler, and valve cover gaskets will eventually leak. The oil cap itself can leak as well. Inexpensive fixes- with the VCG being the most costly here.
Vanos solenoids go as well (read this thread to you know how not to go about fixing it)
Service your car on time and have it scanned - you will be able to view and resolve any faults based on the codes that may come up.
Change your gearbox oil. ZF can do this if you have a ZF box. If you have a GM box - I believe you can use Dexron VI oil but get someone to confirm this first.
K_S said:Car sounds very nice and is very well kept!
Kameelzn14 said:Hey bud today at 4pm were you around Ridge road and Springfield road in Morning side? I saw a white E92 with the style 313 wheels if that was you, your car is looking really sweet
Dirtydeedsman said:Soooo what's the replacement?:fencelook:
