E90 Headlights - Halos & Xenons
Good Evening Guys
I have a 2007 335i E90 my headlights are normal non Xenon, No halos
I Would like to either have Normal Lights and Halos but would prefer Halos and Dim only Xenon's or projectors at least
What are my options for a Direct fit? or if coding is needed where do I get it coded?
DieselFan
Normal lights with halos - E90 lci halogen lights.
Xenons - e90 or e90 lci lights
Or you can retrofit. Speak to sugan at Violet electronics
Xenons - e90 or e90 lci lights do these have Halos? Would love a original set but I am concerned about errors or things not working
DieselFan
Yes.
Car would need to be coded for xenons.
Yes.
Is this a major thing or would I find someone around Pretoria to do it for me?
DieselFan
Yes.
You could do it yourself. Just Google e90 halogen to xenon retrofit. There are guides online.
for the lci xenons you would need to code out the bulb checks for the LEDs
Yes.
Sorry for all the questions is there any wiring changes that need to be made?
Hi Dieselfan
I got this DIY http://www.e90post.com/forums/showthread.php?t=28035 Looks like there aren't any complaints will get some quotes on a set of lights
Hi I contacted Violet Electronics
Thanks for all your help
DieselFan
Yes.
Hi Dieselfan
If you use oem bi-xenon light you have to join the bixenon shutter to the high beams on the plug that they plug into.
