Good day everyone.
I drive a 2006 E90 323 sport and it has 210 000 km on the clock.
There's a couple of things i need some thoughts on, hopefully someone
can help me or shed some light on it.
Every once in a while it puffs out a big cloud of smoke when i start
it, grey-white, doesn't matter how i drive it or anything. It happens
today and out of the blue 2 days or 2 weeks later, doesn't matter if
i red-lined it or whether it was just idling, when i start it, PUFF,
there it is, the car is also sluggish and heavy on petrol, had it at bmw and had a service done not too long ago but its the same.
I think it is valve stamp seals, but because its not smoking with every start up i don't know.
Next is the rpm meter "fishing" not by a lot but you can see it going up and down a bit and it also mis-fires at low rpm, must keep the engine above 1000 rpm to keep it smooth.
I have replaced the number 2 cylinder coil 3 times so far, first two times was at bmw, the last time was a parts dealer, first one went on about 120 000 km,previous to that i dont know, so far i cant tell why its doing that either, i have heard the coils do die, but 3 on the same cylinder? I live in Wonderboom pta, if there is someone that will not ask me a second bond on my house to do a good look over of the car and check it with a OBD reader i would also be very thankful.
Any help or tips would be greatly appreciated in this regard..
Thank you
Thank you
