Spannie said:I think your issue is rear suspension setup. I've had Nankang tyres on a previous car and they were excellent, very grippy in the dry and wet.
DieselFan@TheFanatics said:You paid to keep your own tyres... what a joke. I would have lost my shit.
DieselFan@TheFanatics said:Why are you still using this company?
It's not the tyres. They may be on the budget side but it still wont cause your problems. Also, run-flat tyres have worse road handling than regular tyres, don't go back if you aren't worried about punctures.Deon Rupnarain said:Shame , i made the wife go check the tyre sizes again...i need to edit the original postraise:
Back 255/40/17
Front 225/45/17
I hope the above sizes are correct.
WRT JacksTyres , I clearly remember the guy adjusting the Rear cambers and i found printout but forgot to bring to work today:sorry:
Thanks for the response "X3" . My car will be all over the place if i go on the road at even 100kph.
From what i gather the alignment and the new NON RUNFLATS are the issue, Guess what i forgot to mention ...i paid to keep my original RunFlats which has about 60% life.......
Lets see how it goes on wednesday with BMW.
Thanks alot guys!!!:ty:
Carbon@TheFanatics said:It's not the tyres. They may be on the budget side but it still wont cause your problems. Also, run-flat tyres have worse road handling than regular tyres, don't go back if you aren't worried about punctures.Deon Rupnarain said:Shame , i made the wife go check the tyre sizes again...i need to edit the original postraise:
Back 255/40/17
Front 225/45/17
There are two main causes for unpredictable oversteer, one is mismatched tyre pressures, but the differences have to be extreme, more than 1.5 bar difference.
The other is toe out rear. Less Camber would lessen grip, but more predictably and with fair warning. Toe out (instead of in) would cause snap oversteer and the DSC would freak out.
Check tyre pressures today (2.2 bar all round is a fair start) , and also, don't go to BMW to fix alignment, they would tell you that its the tyres (happened to me). Go to a Hi-Q or similar with a hunter laser alignment machine. It has the car's specs loaded on the system so the operator has no thinking to do. They also charge about R350 for alignment.
AadZO said:Something to think about as well - Non RFT's are lighter than RFT's, so in theory, could they light up easier given similar compound and pressure ? Then again, usually softer, so in theory they should stick more ?
Just a question ...
sash said:the issue about the old tyres has become a norm, most places dont advertise that their prices include your old tyres as they normal sell them off to the next person,
Back 255/40/17
Front 225/45/17
WIDEOPN-X3 said:I refer to the parts bold / underlined
Not sure i agree entirely with the handling hypothesis. There is significantly less sidewall deflection in a runflat tyre so the turn in characteristics of a runflat and normal tyre of same sizes on the front of a car would see the runflat with a "crisper" turn in and theoretically hold the line with few corrections than a normal tyre. Don't forget that the BMW suspension is also set up around runflat tyres which I assure you exhibit different characteristics.
Tested proof. Same car and same tyres, rft vs non rft. Non-Rft wins every single test by quite a significant margin. I do agree that stiff sidewalls can inprove turn-in though, but there are better tyres for that. See test below.
RFT vs Non-RFT Tyre test.
Lets not confuse camber and toe.
I was refering to the differences in handling characteristics between the two, hence the period in the underlined section.
Tyre pressures are extremely important. BMW recommended tyre pressures will see you get maximum 20k km out of the front tyres before they are worn to canvas on the shoulders.
I ran 2.8bar front and 2.6bar rear on my 320d and got 35k km out of the tyres with even wear across the surface. The same applies to my X3 and Tyre Mart Pinetown has the data logged. They were very surprised but the proof is there.
Yes the ride is somewhat harsher but at R15k per set for my X3, I will put up with the harshness to get 50k km out of a set of tyres.
Tyre pressures are important. RFT tyres require much higher pressures than regular Non-RFT tyres as there is a higher torsional force on the tread edge causing so-called "camber-wear".[/color]
Carbon@TheFanatics said:WIDEOPN-X3 said:I refer to the parts bold / underlined
See my response in red.
