E90 320d LCI engine vibration
PizzaBoy
Hi guys
Hope you can shed some light on the matter, i recently noticed annoying vibration on my car, the seat, the steering wheel, gear leaver it feels like engine vibrations its much more noticeable when going uphill and i give more gas, its like when the engine is under load there is more vibration, also sounds like its coming somewhere from the passenger side, i check the engine mounting from the top of the engine bay and they still look in good order, any suggestions?
Regards
Donovan2412
PizzaBoy said:
Hi guys
Regards
Are the wheels and tyres all okay? Aligned and balanced?
PizzaBoy
Yes they are. I feel the vibration even when at idle if i rev it. Its not a unbalanced wheel kind of vibration. I even checked the vibration damper and it seems to be intact and in good condition.
Sent from my SM-N910F using Tapatalk
Rodger001
Check the Vibration Damper. And get the OEM, its the only one that lasts.
+1
Mine did the same and was replaced under motorplan. Solved the problem.
PizzaBoy
How do you know if the damper pully is faulty? I had a look and its seems to be intact
No cracks or anything?
PizzaBoy
I also ready about timeing chain failure. Is there reason for me to be worried about this? Will this also cause vibration?
Rodger001
Chain should not cause a vibration to the degree you are explaining. Would seriously have the Vibration Damper checked by a qualified person. You cannot always see the damage till you remove it.
PizzaBoy
Hi. No stull got the same roghness. Especially when i am trying to revers up a steep hill. It feels if the vibration magnifies.
Regards
PizzaBoy
RAArmstrong said:
Could be engine mounts?
Well i asked BMW to check when it went for service and tbey told me it doesnt look cracked. Did not get time to take it for a 2nd opinion somewhere else yet.
