Hi fanatics!
Race day was a bit hectic, in qualifying session, an engine of another car had a serious electrical problem when a conrod smacked the starter and deposited a huge amount of oil on the racing line into turn 4!! Rally experience saved my day as I was able to yaw skid through this fast section and ended up exiting the curve on the edge of the pavement extension. Other cars skidded straight on into the gravel trap. Red flag came out and we pitted.
I had adjustments made to rear shock rebound settings going a 1/4 softer, and also dialed back on neg camber, as the car suffered slight understeer in turns 2 and six. Tyre wear on the fronts showed that the front susp had too much camber.
I qualified 2nd in class C and 7th overall for the first race with a respectable first attempt 1:12,1 . In the first race, the car still had understeer but much less than during qualiyfing. It took me some time to figure out which gear to select, 2nd or 3rd, for the tight corners. Reason for this is that the shorter diff ratio now renders shorter gears by implication
In lap 7, the alternator power wire touched the one oil cooler pipe, which melted the isolation and it caused a dead short, it was all silent very suddenly. I free-wheeled into the pit entrance and was towed to Freddie's shop. A few extra wires were charcoal and the fuel pump and and battery were cooked as well.
We fixed and replaced all the obvious damaged parts. Bit the car went into limp mode when started and driven. Freddie could only rectify a throttle sensor error when the guys with a DIS analiser pitched up on Tuesday. In the meantime I purchased a good used engine wiring loom from my good Friend Walt for a give-away price, just to make sure that we eliminate any future wiring problems.
Freddie and I decided to fit stiffer springs all round, as discussed earlier during the building process, to curb body roll, also decrease front rebound as well.
Lee will hopefully be able to test drive the M3 on or before coming Wednesday, to assist with final setup.
If rain does not prevent a Wednesday open practice session, I the car should be setup and prepared for the next event, which will be on the 21st, namely the ARRO sprint rally at Boekenhoudskloof Traffic College, in Pretoria West.
The shorter diff ratio works very well, adding to the torque rendering a very healthy figure of 375 Nm @5300 rpm increasing to 420Nm @ 7300 on the wheels, on F2 Vehicle Technology in Pietersbug's Dastek dyno. KW came to 195wkW @ 8000rpm.
I must say, the fine tuning of the suspension to the perfect settings, is só important for fast lap times. This car has a 1:08-1:09 potential at Zwartkops. I am considering a larger oil cooler as well, water temp stays at 90 degrees C, but the oil is getting very hot on a hot track day as it was on Saturday.
So, there you have the race teport after the first outing.
My great boet and friend Riaan Woest and me.
Uncle "Pete the Greek Vanos Expert" and yours truly.
My great dad and I. He is the proud owner of a 2011 BMW Z4 35iS, going full-out in his supprt for my racing.
