steveafster
Sankekur said:You can get a 5 speed box for the later e34 530i's the ones that came with an M60 it will be a straight fit onto your motor, but you will have to either modify the box to take a timing pickup (requires some precision drilling else your timing measurement for the DME will be wrong), or you will have to convert it to front mounted timing....say by going aftermarket ECU or you could go to one of the older DME's from the M60 days.
The 540i, does it have an M62 or M62TU motor?
You best option for a gearbox would be to go for either the box out of the e39 540i manual, or for and e39 M5 box. The 540i one is hen's teeth rare, but are generally a bit cheaper. The M5 one is easier to find, but are more expensive (though it should be cheap for someone that bought an e60 M5 gearbox). Don't listen to what anyone tells you (especially scrapyards) the 540i and M5 boxes are the same, the M5 one is just more expensive because M5.
The e34 540i 6 speed gearbox is also a possibility but will require the same modification as the 5 speed one. Other than that this gearbox is identical to the e39 ones.
Thank you all valid points to return the gearbox is not a problem Now I know what they need to find me the 5 or 6 speed box sounds like a lot less trouble.. again I appreciate the advice that is why I posted the project here. :rollsmile:
Again one of the reasons I posted in this forum is to get Information and Advice however I do not limit my self and believe that if you put your mind to something it can be achieved.
I understand that there would be some that would give negative comments this does not phase me at all only motivates me more to achieve what I want to achieve. I take the positive and negative comments and glean as much information of them as I can use.
So with that I say thank you to all of you for negative or positive input all of it will benefit my project at the end!
:ty::ty::ty:
