msm
I see quite a bit of info on E46 with ZHP packages (in the US). From what I gather it is about the same as our "SA spec" individual/sport packages. However, noticed this today on Wiki and just curious to know if our "local" 330i sports/individuals had a similar power bump:
From Wiki:
In the performance department, the ZHP was equipped with the more aggressive BMW Performance camshafts and a DME tune to increase power from 225 hp (168 kW) to 235 hp (175 kW)[17]. The engine redline was also raised from 6,500 rpm to 6,800 rpm to further take advantage of the new power band and higher power output achieved by the new camshafts at higher RPMs..[18] As a result of the higher redline, the nut that fastens the oil pump's sprocket came with threadlocker pre-applied from the factory to keep the nut from falling off.[19]. The car also received a shorter final drive ratio which allows for faster acceleration; 3.07 vs. 2.93 for manuals and 3.64 vs. 3.38 for the automatic.[18] Car and Driver magazine track-tested the car, which returned a 0-60 mph time of 5.6 seconds and passed through the 1/4 mile in 14.3 seconds.[18] In 2003 the ZHP was the only non-M 3-series to feature a Getrag 6-speed manual transmission (the Steptronic automatic transmission was not available the first model year (2003), but it was offered from 2004-2006."
From Wiki:
