E46 330I SWITCHING OFF
charly333
Hi Guys
I have e46 330i, the car starts but doesn't even idle for a second and switches off only after a couple of attempts it starts and idles.
I have replaced the camshaft sensor and swopped the airflow sensor with one of another vehicle but it does the same thing.
I tested the fuel pump and pressure is fine. The fuel filter was replaced with the last service which was 15000km ago.
Any suggestions.
Spiro
Check your Aux Fuel Pump on the Passenger Side
Make sure your Fuel Pump Relay is working fine...
have you considered a Diag ?
jerzi
Fuel pump coil pack or a relay
Check that your battery terminal I tight and test your bat
The fuel pump also has a filter on the inside check it clean it
firaz
Hi,
Sounds like a "leaking" fuel injectors. Had a similar issue on my 330i. Does it usually battle to start when the engine is warm? How is the cold start up?
Regards,
Firaz
Sent from my HTC One mini 2 using Tapatalk
jerzi
If it is the injectors all you have to do is put tread tape on the studs and tighten properly with out damaging any of them
charly333
Starts up fine when its warm, having an issue on cold start ups.
Diagnostic was done
Camshaft sensor and airflow came up
camshaft sensor was replaced and took the airflow from a buddies car but still does the same thing.
Is there any way to test the fuel pump relay?
