GPGrobler
Jason330i said:Hi guys
Thanks for all ybe replies. I took the car home I was too worried this guy tries to do more damage(if he did in the 1st place) and then gaurantee I need a new engine. unfortunarely I am in JHB (im from cpt) for 2 weeks so I can only take care of this then. I will definately look at the place in parrow when I get back.
Sent from my SM-G930F using Tapatalk
I checked the oil to see if it was lighter or "milky" and the mechanic told me he did a pressure test.. thats part of why I feel like he should take some sort of responsibility but we cant point any fingerszippy320 said:Before replacing the radiator , wouldn't they have done a pressure test and picked up if the head gasket or maybe another gasket ? or some part had a leak? And if water was leaking into the cylinders or some part of the engine , wouldn't that oil water mixture show up in either the engine oil or the expansion tank?
Definately will check him out thanksRayMan101 said:Jason330i said:Any recommendations of a mechaniccape town reasonably priced. I know either way this is gna be an expensive job.
Hey Bud, I had my engine done over last year because my oil pump had a crack and the bloody "stealers" couldn't find the problem and also wanted to replace the head/whole engine for a 100k....
anyways, I took the car to a mate of mine who did pretty much the whole engine over and kept the parts that had no damage (block etc) , so with machining, engineering etc the bill came to just over 30k. So if you want to keep your engine and replace the damaged bits, speak to Charl at Century Auto Clinic in Parow.
good guy and doesn't bullsh!t you.
Wish I was so I could get someone to just take a look.. thank you for the offerGPGrobler said:Jason330i said:Any recommendations of a mechaniccape town reasonably priced. I know either way this is gna be an expensive job.
Please get a second opinion, but a very important question, what did the temperature guage read, was it ever near or in the red for a long time?
Radiator replaced and now blown engine, really? Sounds like this mechanic saw a fat cow and is now trying to milk you.
Are you in GP, then I can swing by and take a look for you for free. :thumbs:
Car did over heat not to full but past half way thats when I pulled overGPGrobler said:Jason330i said:Any recommendations of a mechaniccape town reasonably priced. I know either way this is gna be an expensive job.
My E46 overheated past the halfway mark twice, once from a failed belt, second time from a failed fan, your engine is NOT blown, this guy is Bullshitting you, you pulled over quick enough, just like I did. :thumbs:
