SubLoaded said:
Knock sensor codes or resistance all fine?
hmmm sorry mate, i dont know what happened to my original post...its blank! i had typed quite a long description of the problem. lemme start again:
basically, once i get close to 120kph theres a really hectic knocking/tapping noise that happens from the middle-rear of the car. it sounds like something is hitting something and has a rotational sound to it. as soon as i drop below 120, like around 110-100kph, the noise goes away.its almost like something is hitting a cover or something...its not a metallic noise though. and even if i let off the throttle completely the noise is still there until the speed drops to like 110 or so.
its the first time using this car at that speed since i had the following stuff done about 3 months ago:
- rear subframe/diff bushes replaced
- rear wheel bearings, springs and shocks
- whole front suspension - tied rods, control arms, caster bushing, shocks
the car is auto, and seems to rev okay in lower gear without any noises, problems or dash warning. i had serviced the car about 3 weeks ago, and oil levels are all okay. thanks!
