andrewbuch said:7,4,2,10,12,5
all been replaced but still wobbly/loose gear shifter, might be because the actual shifter was a 2nd hand one
moranor@axis said:
Iceman007 said:moranor@axis said:
:fencelook:
See above about "Spring Detent" and believe me its the cause. Seeing that you replaced most of the other parts already
Iceman007 said:andrewbuch said:7,4,2,10,12,5
The problem is whats called a spring detent. Its located in the gear box and basically centres the gearstick on the 3rd/4th plane. The spring and plunger seize in and it stops centring the gearstick-always on the 5th gear side. It is a gearbox out job to change what is basically a £2 part. But someone on here or dare i say it BMWLAND has managed it from underneath the car with the box installed with very flexible hands and a mirror...! Do a search for gearbox spring detent or words such as...
Read this link for this is your awnser
http://www.bmwland.co.uk/forums/viewtopic.php?t=72465&highlight=detent
:thumbs:
http://www.realoem.com/bmw/showparts.do?model=AL32&mospid=47631&btnr=23_0129&hg=23&fg=15
The problem is in Area 16 to 21. normaly springs
moranor@axis said:
Charlie Brown said:raise: to what iceman says above plus read this http://forum.e46fanatics.com/showthread.php?t=900208
Had my mech do this and the box detent / dedents and it was life changing to be honest, he actually gave most of my parts back, but 12 and 15 are essential.
I have kept the left over parts for the 330i, but a word advice, get the motorsport / ZHP knob like Kabal's first, before deciding on the short shit lever. The knob is shorter and does a pretty good job of a SS.
Iceman007 said:yip he can replace it. its cheap. but it wont solve the problem completely
moranor@axis said:Iceman007 said:yip he can replace it. its cheap. but it wont solve the problem completely
there is no way you can say for sure this is his problem... considering andrew has not mentioned any of the symptoms you mention... there is a good chance you are wrong...
the uprated bush i have solves a big culprit when it comes to loose gearshift and seeing as andrew has already changed most of the bushes it makes sense to finish the job and see if it solves the problem...
