E36 Whine!!!
ver328i
Finished my Auto to Manual Swap last night(2am this morning :fencelook:) and the car drives well but the box makes a whining noise. Sounds like the car is in reverse throughout all gears.
The spigot shaft bearing is new and so is the release bearing. The car does not struggle to go into gear.
Any Ideas? Need this sound to go away:bangdesk:
Inactive
Inactive
Wait before you do anything....drive it for a while. Mine did exactly the same and eventually became quiet after about 5kms.
ver328i
Thanks Bruce - Only saw the response now
Already removed and returned the box - currently waiting on the breaker to supply a replacement one:thumbdo:
Gordvisr
Sabretooth tiger said:
I had that whine in my car, so stopped at the shops, let my mother in law out, and the whine was gone.
i was waiting for something like this :roflol:
ver328i
Should have gone six speed:bangdesk:
The breaker refunded me and I bought a box off gumtree...
Just finished installing and its officially my second faulty gearbox. THIS IS BULLSHIT!!!:argh:
This one is even worse than the one before. It doesn't whine like the other one did but its almost impossible to find any gears. First thing I noticed about the box was that it was almost too clean to be a second hand part...I should have known then and there :cry: The shifter does not jump to its neutral position when you pop it out of fifth gear and when in neutral leans towards 5th. First gear, second gear...fuk'n all gears are impossibly hard to select. Theres no grinding of gears so the syncros seem fine but I know that this will be another expensive repair. :thumbdo:
Seller is adamant that the box was perfect with no issues yet his avoiding me now.
Anyway, we live and we learn right...STAY AWAY FROM GUMTREE!!!
Rodney///Marsh
:roflol::roflol::roflol::roflol::roflol::roflol::roflol::roflol:
Jethro91775
Haha haha. ... If we don't see you around here any more. We know it has been leaked to the mother in law
JayDrft
Hi Ver,
As Bruce mentioned drive it a bit, but you havent had any luck with the replacements that you have had....sorry bud.
I just wanted to ask, did you ever consider putting new box oil in before installing? Keeping in mind these cars are close on 20+ yrs old, most likely that oil was never replaced, and if it stands, it may accumulate surface rust inside and this might cause undesirable issues.
Hope you come right - i got an e30 325 box spare, if all else fails...might need slight mods, but that one didnt have any issues as far as I can recall.
Heres holding thumbs that you get sorted!
Jeremy
ver328i
JayDrft said:
Hi Ver,
Hi Jay..thanks...both the boxes I bought was filled up with the recommended grade fresh oil before I installed. Im seriously considering a Getrag 260 because of the overdrive 5th but then i'll have to buy an m20 clutch kit right?
out of interest though, how much you selling for?
