Solo Man
Hi, need some advice as i am at wits end with the recurring water leak on the M43 motor i am busy fixing. At the back of the head in between the head and the firewall there is a small plastic elbow with a junction that feeds the heater pipes. This pipe goes into the cylinder head about 15mm deep and seals with an O-ring. On this particular head the previous plastic pipe was leaking for a long time and the water has corroded the opening with the result the O-ring on the new plastic pipe cannot make a watertight seal. I have tried a larger diameter O-ring but it still leaks when under pressure. I am contemplating using Pratley Puttey plus the oversize O-ring to seal this but am not sure which product to use as they seem to not like prolonged heat. Any other products i can try in this application that you have tried in a similar situation and gotten positive results??
