George Smooth
That's a real shocking site. Before you start getting heavily into it I would recommend a compression test and maybe a boroscope inspection inside the motor.
S50B32turbo said:OMG my heart is sore, at the same time im happy to know thats its getting alot of love where its at now. Gotech does run vanos, savspeed uses it on both the e46 m3 and e36 m3 without locking vanos. Member born2boost has gotech with vanos on his e36 m3
Gizmo said:May look at VAC vanos delete kit, pending. CT guy said it doesn't run vanos.
Here it was in the cars for sale section some time ago: http://www.bmwfanatics.co.za/showthread.php?tid=15020&pid=139293
http://www.bmwfanatics.co.za/showthread.php?tid=13285&pid=129687
19 posts and last visit 2011 so some douche who joined fanatics, got enough posts to use cars for sale section and dumped a butchered half arse turbo M3. :thumbdo:
Gizmo said:The thing I hate the most is its running on gotech which cannot run vanos so the idiots cut the engine wiring harness and sensors to pieces and blanked off the oil feed to the vanos so there is no going back to OEM ECU!!!
Also there is no idle control valve so you have to pump the accelerator to get it to start.:argh:
Went for R130k, the douche was happy to sell it to someone who hadn't seen it in person...calypso said:Either way the vanos will struggle to run with the connector cut off.
Cant believe that he wanted to sell for 150k, wonder what it actually went for.
Marius has been doing all my tig welding for years, he is the only guy I trust with welding. Will speak to Boetie about the vanos plate.S50B32turbo said:Budler makes vanos locking plates, try him it myt be cheaper than importing. Also his neighbor is marius from fulboost, he does an amazing intake manifold for m's, similar to hpf. Its about R5k.
Whats with CT guys butchering BMWs?:nonono:Squire said:I know the feeling broer, I bought my current E36 from a guy in CPT in June, 1st it was grinding 1st and 2nd gear, repaired the gearbox, found that they had swooped the flywheel so it wasn't taking original BMW clutch kit and had spacers on the pressure plate, no fan and fan clutch, top was messed up missing engine bolts etc. I have just redone the whole motor from scratch and believe you me still no registration papers!![]()
