gazza
You hurting my feelings here...//M SPORT said:If your cam is damaged, I almost certain that your valves are.
Of you have stock cams, those don't break in a hurry so the pressure to the cam was caused by one or more of the cylinders (i.e. piston on valve).
What baffles me is how the engine still turns:skit: That's a good sign but, either way, that engine has to be opened as additional pressure on your pistons could lead to a bent crank.
. Yeah the motor still turns over... Sent from my F3111 using Tapatalk
