Hey guys
So started doing a little work on the car this weekend..
Started with trying to trouble shoot the hooter, checked fuses, relays etc. but nothing.
Took the steering air bag off and theres no power coming through for the hooter.. ended up taking the steering wheel and slip ring off..
Took it apart..
To find the film on the inside is torn..
So this explains why the hooter isn't working, and I'm assuming why the airbag light is showing as well..
Anyway, I moved onto the oil leak..
Got my new gaskets from BMW.
noticed that the rubber bush that goes onto each of the cap nuts were different..
The flat one is what i got from BMW.. checked the part number and seems correct..
While taking things apart i noticed that this was unplugged, seems to be for the vanos..
If this is not plugged in i assume the vanos isn't working??
Tappet cover off.
and old gasket removed. it hard and brittle, broke to pieces..
Gasket was leaking so bad all the plug holes were filled with oil..
decided to remove the plugs to see what they look like..
battle for almost an hour to remove no 4. because some idiot decided to leave an old rubber seal (i assume from a plug spanner) which had now turned hard.. :hammerhead:
plugs look aweful
and 3 of the plug leads are breaking up on the ends..
I then soaked all the nuts and bolts to get them clean and started getting ready to put everything back together but realised that i was short 4 of the rubber bushes.
So covered everything up and will try get the extras tomorrow and finish up.
Does anyone know where the best (cost effective) place to get a new slip ring or is it agents only?
And is the rubber bush that i got from BMW the correct one (flat one)?
Cheers
