GPGrobler
Did you get sorted yet? I think the change in fluid caused the brake piston(s) of that caliper to stick, you need to change the seals in the rear calipers for it to work properly again.
After reading your post again I realised what happened, some dirt or solids moved from the brake lines into the caliper, and this causes the piston to stick, so the caliper itself needs to be removed and serviced.
