There is a heater valve on the passenger side at the back of the engine bay .You either have a voltage problem - check voltage as someone works the heater control from closed to full open , or the vale is stuffed . You can take the pipes off and pull it out ( its tight in the mounting ) and clean it . Good luck . Stealers price ? IIRC about R2K !!
