Hi All,
If anyone knows a scrap yard or any place where i might be able to get a scrapped 325 tds or second hand parts for it, reason i am asking, so desperately i might add, is that i am looking for the bracket that the power steering pump bolts onto, that bracket then bolts onto the block.
My power steering pump broke off the bracket and i need to replace it.
The bracket is aluminium and i had it welded, didn't last for 1 minute as the tension of the fan belt just bent the bracket at the welded points(what a waste of money).
Bemows don't have a tds there as this bracket is not the same as the other 6 cylinder models, so now i need to either find a suitable solution or another tds to remove the bracket from.
Absolutely any ideas will be highly appreciate at this time.
PLEASE HELP!!!
p.s - the gautrain was quite cool today
PLEASE HELP!!!
