dtc button
herr bmw
ok yesterday playing around a bit(was actually bored)if you press the dtc button,it switches it off,correct?
but if you hold it in for a while a symbol comes up on the dash showing a circle with an arrow,around a triangle,what does this do?
it felt a be quicker on pull off.
andrewbuch
Now go have some fun :)
I turn my ASC(I dont have DSC or DTC) off when I need a quicker pull off.. as it intervenes way too easily..
Cause when it intervenes it takes power away so with it off you would be able to get a faster pull off with a bit of wheel spin.. Not too much though, as dropping clutch @ 5000rpm just leaves you with too much tire spin..
The trick is to find the best revs to pull off in your car..
Now on our E90 its an Auto, so no point turning it off as a auto 320i does not spin the wheels on pull off anyway...
herr bmw
well tried it yesterday in the rain,straight line,no wheel spin ,but went like a bat out of hell,i had a big grin:rollsmile:
andrewbuch
Now try it on a not strait line (private, Empty test track recommended)
That's Why I like the skidpan, lets me test it & see how the car handles with out traction control so I know for if it happens in the real world..
But on some road I know, I do play around a bit.
But you are lucky in that you have the 2 stages..
So play with DTC on.. (1 short push, Until DTC shows on dash) this will allow some slipping but not completely off..
herr bmw
will see if there is another skid pan day and try it there,bit dangerous on the roads,loose it ,hit pavement,eina,skidpan loose it and just spin out,no eina
andrewbuch
last 2 skidpans for the year are
7 November 2010
5 December 2010
I Got exams 10 & 14 Nov.. So prob the December one for me if I can find the R170 bucks + Petrol :)
im running tires on the back now that have a slightly higher diameter to the front and im liking it alot the dtc does not kick in as quick because it thinks the wheels are spinning slower than they really are :)
andrewbuch
I had a similar thing when I got the car except it was opposite :) Car felt unsafe..
What sizes you running?
195/65/15 at the back and 205/60/15 at the front think the difference is about 1% if i remember right...
andrewbuch
I had that, but 195/65/15 @ back & 205/60/15 @ front...
Now I got 205/60/15 all round..
But need 2 tires soon, Measured & have 1.5mm tread left :)... Its starting to be a bit squirmish in the turns when a bit wet..
But will be replacing with 205/60/15 so I can keep them rotated correctly.. so as to improve their life, as currently I have different makes on back & front & backs wear too quick...
So will get same same.. so I can rotate nice.. every 5000 Km's
andrewbuch
What you going to do with finished tires :) ?? You know I like drifting & wheel spins etc.. Gona finish them off before getting new ones :)
Dmonic1 RFT tyres FTL
andrewbuch if you not going to run them too the canvas i will still use them :rollsmile:
andrewbuch said:
Dmonic1 said:
You guys have NO respect for the prices of high performance RFT tyres....
Why do you think I am driving a old E46 with 15" tires :) Still about R1000 a tire...
R1000 :fencelook: you can get good tires for 700-500
andrewbuch
Will see what I can do.. Will tell tire place I want them for a crazy friend :)
But I dont have much storage space so as soon as I get them off I will let you know.. maybe organise with SPY007
