BountyHunter94 said:Well not exactly 9 000 but if you dont believe me![]()
Likely that someone has had a go at the cluster.
I know of an e36M3 with a dodgy cluster that revs at 6000rpm when the engine is at half that speed.
BountyHunter94 said:I'll take a video so all of you can see. And there's nothing wrong with my cluster. It's working 100% i just need to replace all of the bulb's
And yes it was 2nd gear at 80-90 km/h
BountyHunter94 said:I know.. I just screwing with ya'll
So how do i get the limiter back or is it best to leave it like it is??
When i bought it i was impressed cause the dealer said they had it chipped. Most probably cause they saw the rev's aren't right.
Who knows someone that can remapp mine. 96 model needs to be remapped post 96 needs to be chipped
Also can you guys hear the vanos? It sounds like the vanos always stays on. It sounds like a bakkie/ldv
BountyHunter94 said:Also can you guys hear the vanos? It sounds like the vanos always stays on. It sounds like a bakkie/ldv
100% correct. 4cyl signal is 2 pulses per engine revolution. 6cyl signal is 3 pulses per engine revolution.e30loading said:Isn't this just because he's using a 4 pot cluster in a 6 pot? There is a cluster test to show which cluster is being used.:tiptoe:
Gizmo said:100% correct. 4cyl signal is 2 pulses per engine revolution. 6cyl signal is 3 pulses per engine revolution.e30loading said:Isn't this just because he's using a 4 pot cluster in a 6 pot? There is a cluster test to show which cluster is being used.:tiptoe:
In the OP case, the 4cyl cluster is being fed 3 pulses per engine revolution and over reading by 33%.
The opposite will happen if you put a 6cyl cluster in a 4cyl e36, the cluster will under read by 33%.
