00:15 and I have just finished a small service on the BMW.
New power steering reservoir lid o-ring-hope it sorts that problem out.
Fresh oil and new filter.
Coolant flush - never got round to doing a proper one after the pump went - there was still small debris that came out of the system.
Replaced the fog lamp - the left wheel well cover seems to have been knocked by something - had to bend the plastics a bit by everything is back in placed and screwed down.
New cabin filter.
And got brake pad sensor for the front - the pervious one fell out of the pad seat and got stuck between then disc and carrier bits. This time round I used a bit of wire to act as a spacer just make sure the fit is tight.
Tomorrow I will take it for a wash, then it will be ready for its trip down to Durban next weekend.
I got two second hand conti's to replace the rubber that was damaged by the during the Midvaal track day- the fronts took some hectic strain that day. So the "new" tires are on the back now.
Also got some new round blind spot mirrors for the ktm- looks much neater will found out Monday if they work better.
