Die_Miek
guys
i read my codes with BMWhat android app, the problem now it it gave the codes in the following format:
271A Oxygen sensor before the cat / Lambda probe before catalyst / VANOS control input bank 1 / Lambda probe front catalyst
2721 AfterCat 02 sensor aging, Bank 1 / Lambda probe aging cat h / unknown fault code / Mixture adaptation, upper speed range, below the lower threshold of plausibility (upper Multiply
2823 Lambda probe heating before cat (shear stress) / Heating oxygen sensor before the cat (shear stress) / Lambda probe heating in front of catalytic converter / Lambda probe heating before the Cat
The problem now is, if you search those codes on the internet i dont find uasefull info.
does anyone know how or where can i find P code equivalent of abovementioned codes.
thanks
thanks
