Die_Miek
2003 e46
I have been having the usual 318 FL issues
1. lack of power under 2000 rpm,
2. occasionl misfire where when I try to pull off, drop clutch, then revs drop to zero and accelerator is unresponsive. i then switch off the car, start it again and it drives off like nothing ever happpend
3. recently this started to happen: while driving in 2nd or 3rd gear the car would lose power, and after 5 or so seconds suddenly have power again.
4. Also while at cruising speed, sometimes the car would, “jerk†very slightly. Like its releasing power;than giving again.
so I had my codes read and 7 came up.
CODE 1: 271A Oxygen sensor before cat (bank 1-signal)
CODE 2: 2721 Lambda sensor ageing after cat
CODE 3: 2823 Heating lambda sensor befor Cat
CODE 4: [0, 0,27,85] Please Refer to the relevant technical manual
CODE 5: 2786 Throttle-valve potentiometer 1
CODE 6: 2787 Throttle-valve potentiometer 2
CODE 7: 278E Diff. pressure sensor suction tube(intake manifold)
my logic goes as follows:
codes 1,2 &3 has to do with my cats. if i kill them will the codes go away or do i have to replace the sensors?
code 4 i dont know WTF that is
codes 5 & 6 has something to with my disa valve. should i replace the disa valve or can those potentiometers be replaced?
code 7 probably related to 5 & 6
thanks in advance
thanks in advance
