bmw335ie90
I have had a rough idle the last week. But only on cold start when its colder outside its worse. At 1st i thought it might be carbon buildup since im at 96000kms so i did the carbon clean on friday and it didn't help my rough idle.
So i downloaded mhd from the app store and read my codes. It shows a misfire on cylinder 1-3 that is bank one. It is also said oxygen sensor before catalytic converter i assume that one is causing the misfire on cyl 1-3 . I will post a few screenshots of the codes. It also says oxygen sensor 2 before the catalytic converter but no misfire on bank 2?. Does this mean both of my pre cat o2's are bad? I am going to clear the codes for the 1st time and see which ones come back after a drive.
My main question is were do you guys buy the oxygen sensor? I can get one from bosch that i can get in 3 days for +- R1700 vs bmw asking R4950 for the SAME PART NUMBER. O boy how i hate the Stealers! :skit:
Sent from my LG-H870 using Tapatalk
There are the codes and that is the 02 sensor i need if i am right.bmw335ie90 said:I have had a rough idle the last week. But only on cold start when its colder outside its worse. At 1st i thought it might be carbon buildup since im at 96000kms so i did the carbon clean on friday and it didn't help my rough idle.
