BMW E46 318Ti 2003 - Oil on the Spark Plug
Freak1
Good Dya Gents,
Can anyone help me perhaps with regards to my car.......i have changed my Coils on this car thrice.......i will be buying 6 cylinder coils as i heard they work better......
Problem at hand is that my 1st Cylinder, its spark plug was drenched in oil once i took it out cleaned it and put it back.(Made it super dry) also switched around my coils.
2 Days later took it out again yet again drenched in oil......what does this mean?
Rings on Piston to be replaced?
Valve Cover gasket to be replaced?
Spark plug gasket replaced?
:bangdesk:
Sankekur
Which part of the plug has oil on it? If its the top part, then you need to change your valve cover gasket, this would also explain why you needed to change coil packs so often.
Freak1
Hi Diablo Jnr do you know anyone in Ruimsig that can run diagnostics at my house.
Sent from my SM-N900 using Tapatalk
