BMW e39 Pre-facelift Niggles
KARMash
Howzit gentlemen
I went to go look at 1998 BMW E39 528I that starts and drives but was parked for a few years. Mileage is 301k, I haven't diagnosed the car but mechanically seems good.
It has the following notable issues:
Exterior Door handles broken - Is this is as simple as sourcing door handles and refitting?
Interior door leavers Broken - how simple of a fix is this?
Not all Electric window buttons work - How do you fix this?
Power steering fluid has built up some sludge - is it as a simple as draining it and pouring new fluid?
Please assist, I look forward to hearing from you guys.
Ahmedy
Hi.
You might want to inspect or do a full refresh on the coolant, water pump, thermostat & thermostat housing. Check for leaks on the radiator alongside the sidewalls . Check coolant reservoir for cracks .
Equally important is engine oil and filter.
May aswell replace the fuel filter too .
From there the brakes would benefit from new fluids too . Being a car that old , brake lines may be perished, so check that too .
The doors jam up and I was told a new door mechanism is needed on our 530d . Haven't had the chance to get that sorted. Perhaps someone with more experience can chime in on that .
We've replaced the window mechanism with an aftermarket one . Wasn't a very quick job to do . Results weren't so good either. Window opens and closes very slowly. Perhaps we didn't do it correctly.
KARMash
Hi.
Thanks so much @Ahmedy. I think this particular car us quite far gone, will require a lot of patience.
TurboLlew
These costs tend to add up very quickly and you will still likely not have a 'great' example. @Neven has a lot of E39 parts should you require them including things like the handles/door cards etc. The problem is that you will have to do a suspension refresh and all the stuff @Ahmedy mentions as well.
If you are willing to hunt for parts, DIY a lot AND also get the car for next to nothing it could work. Just bear in mind what you can find 'decent' to 'nice' E39s for.
KARMash
Howzit @TurboLlew, Yeah you know, I realized that, it's really cheap but I don't think I've got the patience and DIY know how.
Mytfine
Breaker yards are easy to run too but often very pricy. Gumtree and fb marketplace are your friend as you will find many pristine examples been stripped because of gearbox/engine failure.
As an example just the door handles and locks may cost R2000, but be patient and you could probably land a complete interior with the handles and locks for 3.5 to 5k.
KARMash
Thank you @Mytfine, I will definitely keep that in mind.
