Best plugs to use in E46 ///M3
Theo D
Hi guys
Gna be changing the plugs on my 4 pipe soon, whats the difference between the NGK PKR7A and NGK DCPR8EVX as both work in the S54B32 motor according to their website ?
M3_FTW
Theo D said:
Hi guys
Stick to OEM. Check your owners manual.
Theo D
I have the NGK DCPR8EVX's in the vehicle for nearly 8 months, I've done about 5000 kilo's with them and have had no problems. It actually had quite abit more torque, I dont know if it was the plugs or the decat I did which was done on the same day.
Chavoos
DE-CAT I think
I am contemplating using Y5DDC or BKR8EVX or BKR7EVX
In a modified S30B50 M3 motor .
There are diff opinions
griffen
If its any help
I changed from the OEM plugs R125each to the NGK double Platinums R165each and I am happy and their service interval is alot longer than the OEM plugs. I got them from master parts. Car feels more responsive but not much but that OEM plugs had done 7500km. If these plugs stay good for 30000km then I will be happy
Andy1GP
Bumping this old thread for any new info.
I have 2 sets and contemplating which to use.
NGK - DCPR 8EKP (OEM from BMW) Dual tip 0.6mm gap
and
NGK - DCPR 8EVX single tip 0.8mm gap (I'm considering these)
Andy I've used both the EKP and the EVX, The EVX is a shed load cheaper than the EKP. Stuck EKP's in on the last service (The OEM one). No ill effects on either, car was the same on both. The turbo/supercharged/nitrous brigade will be better off with a cooler plug.
Andy1GP
Thanks Glen,
My mind just told me that maybe the single tip (less chamber protrusion) might allow for a better burn. Also reading that the single tip doesn't last as long so I figured maybe it burns better and depletes quicker. Which is fine by me.
I did swap them out when I did valve clearances and nil effect was noticed. Car starts the same, consumption seems the same everything seems the same.
I reckon whichever one you find go for it. I'll probably go back to OEM (next time round) just for peace of mind.
