Best OBDII app on Andriod?
sherwinZ
Anyone had an issue with these bluetooth interface?
I got this one. Connects fine to the phone, but cannot read the car ecu.
calypso
My e46 needed a software update on the DME before it would talk to bluetooth adaptors.
sherwinZ
Eish, will try the adaptor on another vehicle to make sure its not a dud and take it from there. Will check about any updates at the next service.
sherwinZ
:joy: Bluetooth adapter works!
Downloaded BMWhat and it connected successfully.:thumbs:
Then tried Torque again which wasn't connecting, adjusted some settings and it connected :joy
Am more interested in realtime info, so will probrably give the following a try
DashCommand
OBDLink
ScanMaster Lite
CANdroid OBD Dashboard
3V0M-WP
BMW Car Club Member
I did a Trail test over the weekend with the latest version of BMWhat and sent it to them for a free analysis cos it had 14 error codes.
I'm thinking of buying this app cos you can now do coding. The previous versions you couldn't
This is what they sent back. Worried about the Torque errors:
Fault Report - BMWhat - Version: 3.30
Base: E87
Faults: 14
ECUs: 13
Model: 130 i N 52 B 30 A
Battery: 11.0V
Enhanced communication
Alternative connection
Date: 2013-08-11 13:17:48
CHX
Version: 16
Device: >samsung< >m0xx< >GT-I9300<
Motor Control:
Engine / Motor
Fehler: Variable intake manifold 2, Self-diagnosis / Variable intake manifold actuator 2 / Throttle actuator, control
Code: 2AAC
Fehler: Cat conversion 2 / Catalyst Bank 2
Code: 29F5
Fehler: Cat conversion / Catalyst Bank 1 / Catalytic conversion
Code: 29F4
ABS / DSC / Brake:
Dynamische Stabilitaets Kontrolle / DSC
Fehler: Engine torque is not adjustable CAN / Coil outlet (dump) shorted right front / DSC ECU intern / Internal ECU operating error DSC / DSC-internal / Internal Error
Code: 5E19
Fehler: Torque 3 missing message PT-CAN / PT CAN fault / CAN error message / CAN message DME
Code: D356
Fehler: Torque 2 missing message PT-CAN / CAN-BUS open PT CAN / CAN message DME / PT CAN fault / CAN error message
Code: D355
Fehler: Torque 1 missing message PT-CAN / CAN message DME / CAN error message / PT CAN fault
Code: D354
Airbag:
Airbag
ECU OK, no Fault Code
Transmission Control:
Transmission / Getriebe GS 19
ECU not present/no response from ECU
Instrument cluster:
Instrument cluster / Kombiinstrument
Fehler: CAN signal fault engine
Code: A3AD
Fehler: CAN signal fault engine idle / CAN ID failure
Code: A3AE
Fehler: CAN signal fault cruise control
Code: A3AF
Central info display / Zentrales Display
Immobilizer System:
CAS
Park distance control:
Park Distance Control / PDC
Sunroof / Roof:
Sunroof / Schiebedach
Roof / Dach
Audio/Navi/Communication:
Phone / Telefon
Hifi Amplifier / Verstaerker
Tuner Antenna / Antenne
Hybrid Radio USA
Digital Satellite-Tuner USA
Navigation
CD-Changer / Wechsler
Audio-System
Video
Seats:
Seats / Sitze
Seats / Sitze
Systems:
Junction Box Passenger / Beifahrer
Fuel pump / Kraftstoffpumpe
Tire pressure control / Reifendruck Kontrolle
Passive Go System
Car Communication Computer CCC
Car Communication
Anti-theft alarm system:
Interior protection / Innenraumschutz
Theft alarm / Diebstahl Warnanlage
Body:
Trailer / Anhaenger
Fussraummodul /FRM
Air conditioning / Klimaanlage
Fehler: CAN message / CAN message data engine / K-CAN failure / unknown failure K-CAN
Code: E717
Fehler: CAN message / K-CAN failure / Terminal Status K-CAN / Torque 3 CAN message
Code: E71A
Fehler: CAN message / K-CAN failure / Outside temperature K-CAN / CAN message HEAT FLOW engine
Code: E71B
Fehler: CAN message / K-Can failure / CAN message consumer power management
Code: E720
Andrew
I am using Launch X431 via Bluetooth on my iPad. I also have Torque which I use on my Galaxy S3. Loads more functions and options available with the Launch software.
Has anybody had any experience recoding used components that are VIN specific?
Cheers
3V0M-WP
BMW Car Club Member
Die_Miek said:
Richard H said:
A:rollsmile:lso using bmwhapp. Loving it, did dome coding with it as well. Does what it says!:rollsmile:
So in you're opinion, it is worth the R500???
Yeah, is it worth the price and are you limited to coding a few things or as many things other coding apps/pc software can do?
Richard H
Yeah worth it, don't have to plug in a laptop just to read codes. Much easier to use
Sent from my GT-N7100 using Tapatalk HD
darrenrsa
