Anti Rattle Brake Clips?
julestar
Hi Guys, can anyone tell me where i can source anti rattle brake clips for a cooper s 2008? I went to the dealer and they said it comes with the brake pads only...
julestar
hotchocolate said:
That's correct. Do you need front or back?
I need the back ones first as that squeaky noise drives me up the walls... the front are yet start squeaking but since im looking, rather get all 4
hotchocolate
I thought I had a spare set lying around for you but I checked and I must have thrown them out, sorry mate.
Copper slip is your next nest option. Also note that the clips are reusable if not damaged so if you have some spare bucks lying around, maybe by another set of brake pads (FERODO come with clips) and use the clips. Then when you need to replace the brakes again, you have another spare set lying around an you can reuse the old clips.
julestar
Thanks for the advice mate! Will try and hustle some clips from somewhere though i did see some good performance brake pads at GG Motors** for not a bad price:idea:
