ALTA Performance Products Now Available at XclusivModz:
ALTA Performance Mini Cooper R56 Intakes
The ALTA Turbo MINI Cold Air Intake not only adds a proven 10WHP and 10ft-lbs of torque to your 2007+ MINI Cooper Turbo S and JCW, but it also unlocks the sound from your turbo! With our intake not only will you hear the turbo sucking in and compressing the air, but you will hear the OEM blow off valve blowing off too.
SILICONE INTAKE HOSES
The ALTA Five-Ply Silicone Elbow included with our intake, is rated for 200psi, and 400 degrees. Like other ALTA products this part is over built to ensure a lifetime of trouble free use. This is one of the key features to our intake as the bend provides the proper MAF (Mass Air Flow) sensor reading and ensures no Check Engine Lights.
SOUND
With an ALTA intake system your car will make a throaty, deep tone on throttle that is undeniably modified. You will be able to hear your turbo spooling and hear your blow off valve every time it opens. Even the stock one.
ALUMINUM INTAKE BOX
The ALTA Turbo MINI Air Box was designed with light weight aluminum. This provides a stiff, strong, and corrosion proof shroud for the ALTA high flow foam filter and a connection point for the fresh air tube. With a black wrinkle finish powder coat is applied to keep things looking clean and finished for that show appearance under the hood.
HIGH FLOW FOAM FILTER
Included with all ALTA intakes is our high flow foam filter. ALTA Performance filters feature a unique two piece design allowing the user to remove the foam filter element for easy cleaning. Easily run the element under a faucet for cleaning and ring out by hand. Simply slip the foam sleeve back over the filter frame and your ready to go. Many ask us why not a "K&N Style" filter? The quick answer is foam flows much better when dirty.
COLD AIR INTAKE
Our intake is designed to remove the OEM hood scoop plug/screen. During initial testing we found removing this provides consistent ambient temps to the filter. While it's not a traditional "Cold Air Intake" where the filter is located in a fender well, the ALTA Cold Air Intake is just as good as it still gets a constant flow of ambient cold air. This is just one of the reasons why or intake has dyno proven HP! NOTE: On early production cars the screen is decorative only and is sealed off completely. You must remove it for best performance. On later models the scoop screen is mostly open and can be left in place.
NO CHECK ENGINE LIGHTS
When dealing with MAF (Mass Air Flow) sensors, small changes in the intake system can create turbulence. While this may seem insignificant, it can make huge changes to how the car runs. Because we are familiar with this problem, great care was taken to eliminate any turbulence issues that might throw a CEL, or make the car run too lean or rich. What does that mean to you? An increase in performance, proper fuel economy and protection for your engine. ALTA is the only manufacture that takes this concern so seriously and our customers reap the benefits!
Price: R6950.00 - FREE DELIVERY IN SA
Please note that these units are on order only, delivery time 10-12 working days on confirmation of order.
Please feel free to inbox or call us:
[email protected]
072 353 6661 - 012 752 6177
SOUND
ALUMINUM INTAKE BOX
COLD AIR INTAKE
[email protected]
