Bhav_335 said:Can someone help me with the pics?
Tinuva said:Bhav_335 said:Can someone help me with the pics?
If you have the photos on your phone, easiest way is to use Tapatalk to post them.
Otherwise, on the website itself, for me using a PC/Laptop is best.
Bhav_335 said:Tinuva said:Bhav_335 said:Can someone help me with the pics?
Hi, Due to work restrictions I cannot post
Can I email them to you to post on my behalf
Tinuva said:Here you go.
Mileage is high, but its at least an mtech2, mostly a nice spec.
Can see the car had a rough life, but the price aint bad considering.
Bhav_335 said:Hi Guys
2nd report of things found:
Prop shaft Coupling
Oil filter housing kit
selector shaft seal
Water pump
This car has incredible power and is a beast once its up and going on the highwayraise:
I just don't feel I want to spend R40 000 repairing this vehicle:blueCry:
KPM_330 said:Bhav_335 said:Hi Guys
Prop shaft Coupling
selector shaft seal
Water pump
Unfortunately, these are older vehicles that would require upkeep to ensure they stay in good condition. As has been said, you really don't need to do everything in one go. Start with a list of priority items and then work your way through them over time. Oil leaks or shocks, if not bad are something you can live with for now. I am due for a full suspension refresh on mine and whilst costly, I can hardly complain since the car has done 260k on the original items.
That car has the potential to be a really good looking model, just needs some TLC. I would negotiate the price down slightly and then fix things in stages, starting with the cooling system (everything from GoldWagen, including the water pump should set you back around R8k in parts). For cosmetic items or most 'non/low-wearing' parts, scrapyards offer OEM parts for little cost, comparatively.
So long as there isn't any smoke and the car runs well, you should be golden. Also, think about what else you can get for the money and if you think the car's perceived value is higher than it actually costs (driving an E46, is still a BMW vs. what else you can pick up for R70k).
Ultimately though, the choice is yours.. :thumbs:
Bhav_335 said:KPM_330 said:Bhav_335 said:Hi Guys
Prop shaft Coupling
selector shaft seal
Water pump
You are 100% right in the maintenance of an older vehicle, and nothing is actually broken on the vehicle....except for the pulleys making a noise and the steering feeling abit heavy. But with its age I can understand it will need the maintenance to keep it going 100%.
I was buying it for the Wifey to use, but I don't think she would manage being a manual
Regarding the pricing, I unfortunately cannot negotiate as that is the price the vehicle was traded in at
If you do buy the car, I would do the following immediately:Bhav_335 said:KPM_330 said:Bhav_335 said:Hi Guys
Prop shaft Coupling
selector shaft seal
Water pump
evnmopwr said:My bru, That car still looks ok.
At 45k, Its a steal... but go wit 40k Cash and im sure he will take the offer
KPM_330 said:Bhav_335 said:KPM_330 said:Bhav_335 said:Hi Guys
Prop shaft Coupling
selector shaft seal
Water pump
Those pulleys are cheap from BMW, IIRC was something stupid like R1k for all 3 pulleys.. Now that I know the car isn't for you, rather give it a skip and buy something else for the wife.
I have no issues with an older car but I feel a lot better with my wife in a newer, lower mileage car.. The last thing you would want is for your wife to be stranded somewhere.. Not saying it will happen, but you haven't owned this car from low mileage, so you won't really have an idea of how it has been taken care of. It's the same reason I have opted to keep my E46 and buy an E90 as well.
Another fanatic should look at this car, though. Mtech II is such a sweet looking kit and that colour makes it even better.
