Smartiesman
[video=youtube]
Bayn46 said:If I was faced with the same decision, it would definitely be the 335i, compare it to the 330d and you're looking at a difference of about 2l/100km. I could live with paying an extra R100–200 a month.
If fuel consumption is a real issue, then you should be looking at the 320d, probably one of the best engines in the range, next to the N54/5.
Sent from my HTC One X using Tapatalk 2
Josh-ZN said:and where can we buy a 335d?
i think your figures are a bit optimistic. 135i i get between 380 and 400km to a full tank at first click on the pump. if i drive it hard i get around 320 - 350km to a full tank. a 330d i have no idea on but i assume more than 700km to the tank. (3 series tank may be a bit bigger) but the whatever the 330d is a lot more economical. not only R100-R200 extra per month. I would fill up my tank approx twice to every once in the 330d
Dmonic1 said:also a 330d is not going to meet your needs you will probably want a 335i with s/w....
Trublue said:my wife has a 135 and gets roughly 400 kms on a tank and she doesnt drive fast
RenVilo said:I worked out that on normal driving I should get about 550/600km on a tank else around 450/500km if I push it
msm said:[A 330d can also get s/w ... :slap:
kabal said:fuel consumption, lol
R7000+ pm/repayments, and worrying about R100-R300 differences pm in fueld :rollsmile:
Bayn46 said:Josh-ZN said:and where can we buy a 335d?
Yep, 3 series is 61l, the 1 series is 53l. If you compare the overall consumption figures for both cars, using those quoted by BMW, the difference is just short of 3l/100km. Yes, my estimate for cost is off because it depends on how much driving you do in a month.
I can't see that either of the above will be worse than the modded ST.
Nastaliq said:Bayn46 said:Josh-ZN said:and where can we buy a 335d?
Never use the figures quoted by BMW, they are almost never even close to actual real life figures.
