Check for vacuum leaks, crank position sensor, MAF. Any other symptoms like loss in power, jerky power delivery? Without more info it could be any number of things from a sensors to something very serious so like LZ said do some diagnostics.
Actually, Legacy...... come to mention vacuum leaks,
THere is a breather pipe that runs the lengh of the intake, this pipe traditionally gets crushed under the plastic cover and becomes very "holy" rather quickly..
I do not think I have worked on one N42/N46 where this pipe (and some others) was not shot...
@legacy- the car does tend to lose power between the gears.... like a dead spot. i was also thinking diagnostic test.... will have to get it done asap coz the fuel consumption in messed up and the power is slacking.
