318i rev is hunting
ysn001
hi Gents
my car is doing some funny $h!t.....
while the car is idling... the rev automatically goes to like 1500rpm and then drops... and it keeps on doing it....
could it be a sensor or something?
please assist
thanks
Krinash
ysn001 said:
hi Gents
please assist
thanks
Could be your idle valve. You need to have it cleaned. You might have to adjust your airflow to get her to run/breed/burn smooth again :idea:
ysn001
Krinash said:
ysn001 said:
hi Gents
please assist
thanks
thanks for the response.... but where is the idle valve..... lol
zaleonardz
Howdy man,
What 318, do you know specifically what engine, N42, N46...
Look inside the engine bay, it should be on a sticker.
What year is the car ?
ysn001
zaleonardz@DentDoctor said:
Howdy man,
Leka n u boss?
dont have the car with me but its 2004 e46 318.
thanks
Legacy
Check for vacuum leaks, crank position sensor, MAF. Any other symptoms like loss in power, jerky power delivery? Without more info it could be any number of things from a sensors to something very serious so like LZ said do some diagnostics.
zaleonardz
Actually, Legacy...... come to mention vacuum leaks,
THere is a breather pipe that runs the lengh of the intake, this pipe traditionally gets crushed under the plastic cover and becomes very "holy" rather quickly..
I do not think I have worked on one N42/N46 where this pipe (and some others) was not shot...
But yea, again, diagnostics is your best bet here :)
frikkieh
I would still suggest that the diagnostics get done. It can point out a faulty cam position sensor (not sure if your car has one though).
Twinz
Forum - Support
Its the HPFP...:roflol:
Sorry could not resist...whenever i hear about rev needles on the hunt, i get reminded ...:rollsmile:
Die_Miek
can you post a link on realoem please :rollsmile:
ysn001
@legacy- the car does tend to lose power between the gears.... like a dead spot. i was also thinking diagnostic test.... will have to get it done asap coz the fuel consumption in messed up and the power is slacking.
