ChefDJ said:Nothing should ever be unplugged :fencelook:
Grills look nice. Are you going to do the T-piece in the lower intake?
a1exander said:Those should be unplugged.
The gearbox needs an oil change as you are now getting the first warning signs of failure, changing is no guarantee that it will not fail.
That box will be a good R30k to repair should it faill..
Oil is typically 2500 as well as roughly R1500 for filter and gasket (check prices with agents)
If the car has done more than 10 000Km the vanos seals are toast.
Drive it in good health.
rodga said:a1exander said:Those should be unplugged.
Ah OK thanks
Are you talking about when the car goes into limp mode? Is it related to a gearbox problem, indicative of failing in the future? I read that depending on the current state an oil change could cause the box to go sooner....?
Sent from my SM-N900 using Tapatalk
Start a GB in the 5series section.ChefDJ said:Also wants M5 mirrors :fencelook:
Gizmo said:Those 2 extra plugs are for post cat O2 sensors but because South Africa doesn't have emissions laws they weren't needed, the engine uses just the 2 pre cat O2 sensors to adjust the a/f mixture. On USA, Europe and Japan models which had emissions laws they used 4x O2 sensors, 2 pre cat and 2 post cat.
I'm loving your touring and what you doing with it. Next thing is bigger oem wheels and m5 mirrors...:fencelook:
