Hi -
I recently changed the turbo on my 320D - everything was changed from air filter, breather, oil seperator, oil, EGR valve was cleaned - but the car was still smoking (white/blue) quite a bit.
Any way, i took it for a little road test. the car reved by its self to about 5000rpm, i quickly turned the ignition off and it still remained reving???? the revs came down and the car switched of after a couple of seconds in a puff of smoke..........now the car will not start - is this it for my 320d??
Has anyone of you has had similar experience or might have any opinion as to what the problem could be??
Any help would be much appreciated.
