to say it has nothing to do with oil temp is too simplistic...
seems to me a major cause of oil heat is the piston because it cannot be cooled much by the radiator system...
ceramic coating on pistons reduces oil temps because it helps to stop heat transfer though the piston...
if you inject a mixture with alot of water it cools the combustion chamber and pistons...
No effect on oil temp? seems to me no one has tried because they more interested in knock suppression and tend to run more meth to make more power(meth only cools charge)...
anyway im not interested in arguing i just assumed that because you already running very high octane fuel you might be looking at w/m to help keep temperatures down rather than boosting octane...
keep up the good work
