135i oil consumption
Rushil
Hey guys...
How often does your car need an oil top up?
About a month and a half ago I had to book my car in for a topup. If I'm not mistaken it was topped up with 4 litres. Then, today as I get into work my oil light comes on saying that I require 1 litre. Is this normal?
Thanks!
S
SP33DYV
What's the mileage?
And yes, apparently it's normal. :thumbdo:
Auditor
I see there are tuners selling oil separator kits for this problem. It also explains why carbon cleaning of the intake is a something that most N54 and 55 owners end up having to do.
akash
Thats does not sound normal.
What was the time period from the time the oil light came on till you took it to the dealership.4L of oil is alot of oil to top up.
The oil light will only come on when it requires 1L of oil. So it would be a couple of months before you took it in?
The last time a topped up oil was in August when i drove to Durban.
BeamerMan
That doesn't sound right..
The last time I put oil in was a while ago (couple of months).. other than that just an oil change for service purposes.
Rushil
Ok sorry. Got this a bit wrong...car went in for 1L topup one month ago and nor suddenly requires another. Still does not seem right
hoosain
how many km did you do in that month?
if you do a lot of spirited driving than the consumption of 1l is normal
akash
The common leaks are at the oil filter housing gasket and the oil filter housing heat exchange. Have a look to see if you can spot any oil.
Zeral1ty
Also check that the oil sensor isn't faulty (apparently pretty common)...happened to me once, one day oil is fine then next day oil low warning is on. Went away the next day though...
Rushil
Do around 1500kms a month
Car booked in for Thursday....will give you guys feedback
Rushil
Ok so booked car in this morning. Service advisor reckons that car could use up to 700ml oil for every 1000kms. Seems very excessive to me. Waiting on further news...
