Diff Oil Change - 247 xxx km
This has been something that I've been wanting to do for a while but was always a bit scared to tackle on my own for some or other reason. After watching a few YouTube videos, I realised that it's actually quite straight forward. I acquired the necessary tools, ordered the correct oil and proceeded with the job
You do not require a lift to do this. There are many videos showing how guys do the diff oil change using jack stands
Items Required:
14mm hex socket
Socket extension bar
Torque wrench
Oil extractor pump
Measuring jug
1l of 75w-90 gear oil
First up is to get the car lifted and loosen the 14mm hex plug
After removing the plug, insert the suction side of your extractor pump into the hole and pump out all the old oil. I used an extractor pump which I bough a while back from Adendorff. I just changed the suction side pipe to a larger diameter as the pipe supplied is quite small. Wiggle the pipe around until all oil is removed. The diff takes 1l of oil but you might not always get all out
Old oil being extracted. Oil didn't look too bad considering the mileage. As far as Wayne and I are aware, this is the first time the diff oil is being changed
After extracting the old oil, I reversed the process by pumping the new oil back in. I was fortunate to have removed close to the full 1l of old oil
Once completed, I cleaned up the excess oil spills and torqued the diff plug back to 60nm
The job took me around 20 minutes in total to complete
Hope this posts helps someone who might want to tackle this job as a DIY
Items Required:
14mm hex socket
Torque wrench
Oil extractor pump
Measuring jug
