Red duck tail 🦆
Dealing with some rain in JHB.
The water was not that deep, so no risk of electrical damage.
The main risk came from the hidden potholes on this road ☠️.
I had to crawl through this road while bakkies created waves driving past 🌊🌊🌊
Since the engine and its air intakes are in the rear of the car, the risk of waves from passing cars in the front causing hydrolock is low. The front intakes in the 911 are for cooling.
Anyway, just showing that a 911 can be used in almost any road condition, when driven sensibly.
Met up with another ducktailed Guards Red 991.1 on a run to Muldersdrift.
Picture taken from mate following us.
Fuel consumption for this spirited drive was a respectable 10.2 litres per 100km
The car has crossed over 60,000km. The next service (minor, oil service) is up next month.
Michelin PS4s last fitted at 39,000km are still in good condition. These are the best road tyres for performance cars, full stop.
Annual mileage has dropped a bit, given change in working arrangements at office (fewer days in).
Expected to be well over 60,000km by now.
Summary of issues since taking ownership at 32,000km in March 2024:
1. Lifting interior door panels. Fixed under plan.
2. Change over valves replaced. Fixed under plan.
3. Rear windscreen seal cosmetic only issue. Entire rear windscreen replaced under plan.
4. Small oil sweat was due to Oil Pump Solenoid Cover O-Ring. Fixed at my cost.
5. Usual brake pads replacement. Not an issue, just normal wear and tear after 23,000km of spirited and daily use. Replaced at my cost.
6. Alarm siren fault. Replaced under plan.
7. Sports chrono stopwatch little minute hand (the small clock inside the larger stopwatch) has dropped off. The stopwatch still works and the digital clock works inside it, so just letting this cosmetic issue be as is for now. Replacement clock is around R18k. The hand can be stuck back on, but the DIY process is complicated.
Not issues, but for noting:
1. Tyres replaced at 40,000km. The old set had decent tread, but being a garage queen (previous owner) meant that these tyres were old and not that grippy.
2. Porsche sports exhaust retrofitted at 50,000km. Sound has improved after longer distance driving.
3. Spare wheel and tools and jack purchased and added to front trunk.
The car is still solid and drives well. After driving my Volvo XC60 B5 Polestar Optimised car, I am being spoilt by the instantaneous torque on pull away and immediate response. The 991.1 needs revs to progressively build up its power, so the Volvo will pull away faster in traffic, unless launching the Porsche in full on launch mode. Ironically, the Porsche is the more responsible car to drive, since you need to be more deliberate with your inputs. Not complaining :)
Wacky Wednesday:)
The car is officially a teenager :)
Went in for its 13th year service last week.
Oil change and usual checks.
Everything in order.
Mileage on 62,000km.
Next 15,000km/1 year is the intermediate service.
Major service is due at 30,000km/2 years from now.
I am now averaging around 15,000km pa, so I will hit one service milestone a year around Feb.
Valuation from AutoTrader, out of interest. Even if I were to sell, there is nothing out there, at this price, that can match the feeling of driving this car (besides another used 911). This is not an investment piece and it will lose some value as I rock up the mileage, but I don't care :)
Teenager...thats not your average 3 year old car condition. Some care that are even less than 3 years of age look a tone worse.
Teenager...thats not your average 3 year old car condition. Some cars that are even less than 3 years of age look a tone worse.
Thanks man.
The Guards Red colour is a good choice to hide dust and dirt.
I only wash the car (at Mo's Carwash in Kyalami) twice a month. No special valet, no fancy products. Just the basic wash. Leather treatment maybe twice a year.
The Ultrafit PPF is standing up well.
As a daily driver, I don't baby this car too much ;)
Salt
I've always admired your car. I open your thread whenever it comes up as a new post. The that red in your car is just something else plus those rims in that colour works soooo well. Glad you're enjoying it! BTW...thanks for the info the other day, I picked up a Steelmate tpms kit last week and had it installed...so glad I did it and feel so much more comfortable now that I can see real time pressures.
1 Eyed Monkey
I daily an Isuzu E\cab, and I get hella nervous whenever I have to drive through water.
Kudo's to you, sir!
Kudo's to you, sir!
It wasn't that deep in reality :)
The waves from the oncoming traffic made it appear worse that it is.
But thank you for the compliment.
On another note, I drove to Hartbeespoort on Sunday through rain and with the family onboard.
I took it very slow because you don't really know where the potholes are sitting.
Went well and slow and steady approach is what works best.
"It’s a car that can be comfortably driven every day, on long highway stretches or city commutes, yet transforms effortlessly into an exhilarating machine on winding roads or track days. Few sports cars manage to cover such a wide range of abilities so convincingly"
Stuttcars.com
Tyre update
Michelin pilot sport 4s fitted at just under 40,000km. Currently at 64,000km and while the tread looks good (checked when parked on the ground), I know the 911's rear suspension is set up so the inner sides of the rear tyres wear out more.
Porsche Johannesburg offer a free tyre evaluation. They put the car on a lift and checked the tread wear on all the tyres, on the inner and outer sections.
Results for the rear tyres are below. These are measured from the TWI (so, add 1.6mm to the below results - so around 4mm remaining).
For daily use and weekend blasting, I am happy with the tread wear on the rears after 24,000km. The fronts are around 5mm. I will likely end up replacing the rears in the next few months.
My aftermarket Steelmate TPMS is still working well and is quite accurate too. When it comes time to replace the tyres, I may end up buying a new system instead of buying just the replacement sensors (4 sensors, bought individually, work out to price of full system with screen unit).
Fuel economy:
Aiming to leave work after traffic peak (after 6pm) has yielded impressive fuel consumption figures. My commute times are now mainly off peak and this is helping me save fuel. There is no need for a seperate daily runner.
