Quick///M
Noticeable weight reduction thanks to intelligent lightweight design
BMW M GmbH has reduced the weight of the special edition by roughly 30 kilograms compared to the standard M2. This has been achieved through modifications including judicious use of lightweight design techniques. For example, the BMW M2 CS features a multitude of exterior and interior components made from carbon-fibre-reinforced plastic (CFRP). And it will be fitted as standard with forged M light-alloy wheels. As a result, the CS will be the lightest BMW M2 so far in the current generation.
Upgraded six-cylinder in-line engine with significant increase in power output and torque
For the BMW M2 CS, BMW M GmbH has opted for an upgraded version of the 3.0-litre, six-cylinder in-line engine found in the standard M2. This intensifies the performance experience in the special edition, particularly in highly dynamic driving situations. It further sharpens the engine’s unmistakable power characteristics and perfectly accentuates the linear power delivery – sustained into the higher reaches of the rev range – familiar from M models. Compared to the BMW M2 with standard eight-speed M Steptronic transmission with Drivelogic, maximum torque has been raised by 50 Nm (37 lb-ft) to 650 Nm (479 lb-ft) and is available across a broad rev range – between 2,650 and 5,730 rpm. The engine produces its maximum power output of 390 kW/530 hp at 6,250 rpm, with the engine speed topping out at 7,200 rpm. In order to allow extremely rapid reactions to the driver’s requests for acceleration and to make the improved performance characteristics of the engine a particularly intense experience, the accelerator mapping and response have been optimised in all.
https://www.cars.co.za/motoring-news/390-kw-bmw-m2-cs-confirmed-for-sa/291812/
