General.Massacre
Hi all.
So another update, sorry its been silent here.
So last week i noticed the AFR is very lean, and also when speaking to @Bugger he recommended i replace the gaskets in each turbo inlet, i did notice the inlet boxes on each turbo were reasonably loose, which may attribute to the fact that its allowing in unmetered air post-MAF, so i order from Craig at Century City BMW, and fitted them.
Also my Short Term Fuel Trims were reading 0 on bank 2, so something wasnt lekker
After installing the inlet boxes fit nice and snug with little to no movement. after fitting, i logged the car at idle, and noted that the STFT were reading and oscillating between backs as they should, so thats at least a plus, the AFR seemed a bit better too, however still lean, and when doing a pull, stayed around 14.3 AFR even up around 4500rpm, as well as boost staying as low as 11psi and struggling to build. so after seeing those details, i no longer logged, and turned around and went home.
the car was still smoking, and i have been setting up the camera in my garage as i reverse in to get a better view, and this has been the view pretty much every time.
You can see the smoke as i come into the garage, and it pretty much engulfs the car. so it is considerable.
Anyways, I did call Boetie last week, and explained the checks and attempts ive done, as well as the progress on putting on additional mileage, he asked if its smoking, and when i said yes, he said right, this should be cleared up, so there is indeed an issue, and that its time the car gets its way back to the shop, he said he will send a truck to collect the car, as well as deliver it when its completed.
So Saturday morning i gave the car a wash, and a roll back came through, i drove it on, and off she went.
I got word this morning that the car is at the transport Depot, and is awaiting collection by boetie personally.
This will be a great time for him to drive the car, and get a look at the conditions and smoke.
So now its a case of waiting to hear from the Budler team.
Have to say the guy has been patient and willing to listen to progress and concerns.
